kthorngr Mon, 04/07/2003 - 16:58
  • Cisco Employee,
Try adding the following global config command to your 2620:
mgcp dtmf-relay voip codec all mode out-of-band
sja9655 Tue, 04/08/2003 - 09:36
thanks for the reply.
The problem ended up being in nortel op 11.
They did not have supervision turned on the cas tie trunk config
Go Figure!!
