Connecting two routers via AUX and Console ports.....
adam.wilkins
Can I connect two routers together via the Console port of one and the Aux port of another? If so, how?
Adam Wilkins
8 Replies 8
adam.wilkins
By the way.......it has to connect AUX to CONSOLE. Not AUX to AUX or CONSOLE to CONSOLE....can it be done?
I guess you are trying to console from one router to another.
Yes its possible
Just use a rollover flat cable ( the blue or black flat cable that comes with cisco routers/switches). Use it to connect from aux of one router to console of other router.
On the router (aux), configure reverse-telnet configurations so that you can telnet into second router through the aux port.
Check this link out
http://www.cisco.com/warp/public/793/access_dial/comm_server.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
The configuration on the URL you provided is for a router that has an async module installed in it. I was hoping for a config that would show the AUX port configuration for a router that is connected to another router's Console port via it's AUX port.
Again, it has to be Aux to Console. Nothing else works for me given my present situation and configuration....
Configurations are similar....
Ok do this...Give a "show line" and find the TTY number of aux port. Mostly it should be 1. A typical 2500 router would display show line output as,
Router#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 0 0 0/0 -
1 AUX 9600/9600 - - - - - 0 6 0/0 -
2 VTY - - - - - 0 0 0/0 -
3 VTY - - - - - 0 0 0/0 -
4 VTY - - - - - 0 0 0/0 -
5 VTY - - - - - 0 0 0/0 -
6 VTY - - - - - 0 0 0/0 -
Apply the following config on to the router from which u want to telnet.
int lo 0
ip add 1.1.1.1 255.255.255.255
line 1
transport input all
no exec
ip host r1 2001 1.1.1.1
Use "telnet r1" or "r1" to reverse telnet to second router.
Hope that helps!
Sankar Nair
line aux 0
transport input telnet
no exec
make sure that you have at least 1 interface that is up up on the router then do
telnet x.x.x.x line #
if you do a sh line as shown above it will give you the line # of the aux port.
the x.x.x.x represents the ip address of the interface that is up up on your router .
Also make sure that the console you are connecting to does NOT have no exec. applied
Thanks for all of your help. I got it working.
Thanks!
What type of cable did you use?
basically, you need a rollover/null modem cable. This is a cable where all pins are reversed. So on one side you have pins 1,2,3,,5,6,7,8, and on the other side, the corresponding pins are 8,7,6,5,4,3,2,1.
Depending on the router model you have, you might also need a DB-9 to RJ45 converter.
