Warning message
session object has timed out (CM 3.3.2)
Apr 10th, 2003
I ran into the following problem on a new CM 3.3(2) install:
Symtom: When Admin adding new user from Add a New User page the follow error
message display
TimeError
The following error occurred while trying to load the requested page.
Sorry, your session object has timed out.
Click here to Begin a New Search
This is documented in bug CSCdv62156.
Unfortunately the workaround provided did not work. I found that if I open the ccmadmin page using the ip address of the server instead of the name you do not run into this problem. http://<ip address>/ccmadmin
Hope this helps.
Frank
ivillegas Wed, 04/16/2003 - 12:14
  • Silver, 250 points or more
Check the bug CSCdw52774. Non DNS characters (like underscore) are not allowed as Server Name in IE 5.5 with SP2 and Q313675 patch.
