Warning message
AP vs Wireless Bridge in AP mode
Apr 11th, 2003
What is the difference between AP and Wireless Bridge in AP mode? Or, when to use AP like device and when Wireless Bridge in AP mode?
Thanks for cooperation.
Jovan M., CCNA
amitubale Fri, 04/11/2003 - 11:40
BR350 as access points can be used to cover outdoor areas, since they have metal case for durability and plenum rating and an extended operating temperature rating for harsh environments
Other than that BR350 in AP mode is jus similar to AP350(not the pastic ones, the metal plenum rated) if you use for indoor coverage.
From Cisco documentations.
The bridge as a rugged access point connected to the wired LAN. When you select Access Point, the bridge's Spanning Tree Protocol (STP) function is disabled. Figure 3-4 shows a bridge set up as a rugged access point.
http://www.cisco.com/en/US/products/hw/wireless/ps458/products_configuration_guide_chapter09186a008007f77f.html#25614
http://www.cisco.com/en/US/products/hw/wireless/ps458/ps460/index.html
mmangat Sun, 07/14/2013 - 19:15
AP (Access point) mode:
will allow you to add wireless access to  en existing router or switch.
Bridge mode:
will  allow you to connect two or more networks or network devices separated  physically to each other wirelessly to make a connection, operating on  the 802.11 standard.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
