Warning message
Unity 2.4.6 Message accidentally forwarded to EVERYONE
lindborg Fri, 04/11/2003 - 07:56
  • Cisco Employee,
The only way this can be done is by addressing the message to a public distribution lists that contains everyone (i.e. the "all subscribers" distribution list).
Other than having folks be more careful about checking to be sure they've addressed the message properly you can prevent the usage of public distribution lists entirely I suppose... this can be done at the class of service level or you can do it globally on a per DL basis by not assigning voice names or extensions to distribution lists such that they can't be addressed over the phone.
Thanks for you help! I am not quite sure what is the best thing to do at this point. Should I remove everyone from the "all subscribers" Public Distribution List (I am afraid of breaking something else if I do this)? I had a look at the COS but couldn't figure out how to disable Public Distribution Lists. Thanks for helping a neophyte Unity admin!
lindborg Fri, 04/11/2003 - 08:37
  • Cisco Employee,
No need to get rid of users in the all subscribers DL - it wouldn't break anything if you did that but it's unnecessary.
On the class of service page in the SA go to the "messages" page. There should be a checkbox there called "Subscribes can send messages to public distribution lists". You can uncheck it.
Before doing that I'd make _sure_ this is what you want to do - if other folks on the system are using public distribution lists it may be harsh to restrict everyone from using them simply because one person was careless...
