Warning message
1760V Fax Relay / Pass-through Support?
Apr 15th, 2003
http://www.cisco.com/warp/public/788/AVVID/avvid_fax_support.html
It says that this gateway doesn't support fax relay or pass-through faxing.
I was looking at deploying 1760V's with PRI's to offices, and ATA's on the fax machine.
Ok. If the matrix says it does not support fax pass-through... then will the 1760V not support "pass-through" to the ATA on the fax machine?
-Jason
dgoodwin Fri, 04/18/2003 - 21:16
  • Cisco Employee,
Hi Jason,
Using 12.2(11)YU software on the 1760, Fax passthrough (required when using ATA18x) is supported. You'll have to use H.323 to talk to the 1760, unless the CallManager is running 3.3.
