Warning message
ATM on Fractional E1
Apr 15th, 2003
We need to carry ATM on a Fractional E1 using a 8500 Switch (or MGX 8800)
* Is this feature supported in these platforms?
* What module implements the feature?
* How can it be configured?
Thank you in advance.
xge Tue, 04/22/2003 - 00:50
No. Seems ATM forum has no such standard for ATM over F-E1.
jaomede1 Tue, 04/22/2003 - 00:57
The standard I am refering to is AF-PHY-0130 (ATM on Fractional E1/T1). It is an approved standard (October 1999).
JOSE
peter.payne Wed, 04/23/2003 - 16:13
I know the AUSM card carries ATM over E1s but as to whether it supports fractional E1s.. I really don't know. More typically the AUSM card seems to be used for IMA (inverse multiplexing of ATM). It is an 8-port E1 half-height card (when used in the MGX8800).
