Selective Java applet blocking by external address with PIX?
bhockenhull
I'm trying to implement Java applet blocking on my PIX, and I'm looking for a way to be more selective about how i do it.
According to the documentation, I can permit certain internal addresses to get Java applets from the outside, but it doesn't seem that I can permit all internal addresses to get Java applets only from certain external addresses.
I can do this (but would prefer not to) at my border router with CBAC using access lists, but the same functionality doesn't seem to be present in the PIX.
yizhar
HI.
Did you read this:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/cmdref/df.htm#1039734
According to the above document, you can specify either internal and/or external addresses in the "filter java" command. Did you try it?
What is your pix OS version?
What is the exact command that you try?
Yizhar
I saw that, but I can't translate that into what I want to do. Maybe I'm missing something.
What I want to do is to deny Java applets from all foreign hosts except fro those I define as friendly. Using CBAC, I'd set up a java access list along these lines:
access-list XX permit 12.0.3.0 0.0.0.255
access-list XX deny any
Which would allow Java applets from 12.0.3.0/24 but deny them from everyone else.
If I could use the filter java command to filter all java *except* certain stuff, that'd be perfect.
