Warning message
How to configure 2 CSM modules in 6500 ?
Apr 17th, 2003
hi,
6500 supports multiple CSM modules in one chassis. I check the configuation about the CSM with 2 modes one is rp and another is csm. another mether is to enter the csm module. Does anyone know the current way to setup the 2 csm modules in one 6500 or give me a sample ?
best regards.
fred.
mishao Sun, 04/20/2003 - 20:32
hi,
I can't see any configure about the second CSM in CSM mode.
This is my problem.
best regards.
fred.
Gilles Dufour Wed, 04/30/2003 - 04:25
  • Cisco Employee,
what do you mean you don't see the config ?
You should create it after entering the following 'mod csm '
I have 2 in the same catalyst and I can see the config for both.
Gilles.
