Warning message
Cisco Secure 4.0 syslog output?
hadbou Thu, 04/24/2003 - 07:36
  • Bronze, 100 points or more
I think this feature is supported only from management platforms and not from the underlying O/S.
ishah Wed, 04/30/2003 - 05:43
You can do this with CSPM via using activestate perl, the net-syslog library and a simple perl script which gets the parameters from the alert and sends them as a syslog to whereever.
You can call the script under notifications
With IDS-MC you can use the perl that comes with it, the legacy perl script and do similiar.
Cisco Threat Response will send SNMP traps on alerts if configured.
I don't think the IDM does any of this but it does use Mysql so you might be able to do something there too.
