Warning message
Changing the number of PRI Channels used on 6608
Apr 17th, 2003
We are running CCM 3.2 with a 6608 for 4 pri's. What I am trying to do is change the number of channels used on the gateway. currently it is set to use all channels on the 4 pri's, and I would like to know how I can change it to only use part of the channels.
rfrome Fri, 04/18/2003 - 10:14
The only way to do that would be to take the channels out of service. From CM service parameters, use the ChangeBChannelMaintenanceStatus1 parameter to take the B Channels out of service. Click on the service parameter link to get the syntax for this parameters.
