Warning message
tepatel Thu, 04/17/2003 - 10:53
  • Cisco Employee,
No..you do not need to reload the router in either case. If you want change the switch-type under the interface, just shut down the controller first and then change it.
Also you don't need to reboot the router to change the global switch-type. Switch-type configured under the Interface will over-right the global switch-type.
makchitale Thu, 04/17/2003 - 11:13
  • Silver, 250 points or more
If I not mistaken, the reload after changing the isdn switch type was on older IOS images (prior 11.3)...the newer IOS will not require it.
Just curious what IOS image are you running?
Thanks, Mak.
