Long Reach Ethernet solution
Apr 18th, 2003
I have two buldings with 1000 meter. I have betwenn these bulding a twisted cooper cable (224 pairs) wich is use to deport a phones line from one bulding to another.
To day i use two modem from RAD Communications but the speed is limited at 2 Mb. I want to have 05 or 10 Mb like speed.
Can i use LRE solution to solve this problem ?
What LRE devices can i use ?
ndoshi Fri, 04/18/2003 - 20:26
  • Cisco Employee,
Hi ,
If you already have twisted copper wire laid out LRE is very good solution .
You can get speed between 5-15 meg . It depends on type of wire you are using and also distance
Please look at this LRE white paper
http://www.cisco.com/en/US/products/hw/switches/ps605/products_white_paper09186a0080088896.shtml
Here is our LRE products
http://www.cisco.com/en/US/products/hw/switches/ps605/products_data_sheet09186a0080088894.html
I hope this helps
Nilesh
