Warning message
Etherchannel configuration on 7500series routers
Apr 18th, 2003
Does anyone know if all ip information i.e. secondary ip address, nat have to be moved from the individual FasEthernet Interface to the Etherchannel interface as well as the ip address?
donewald Fri, 04/18/2003 - 15:18
  • Silver, 250 points or more
When configuring Etherchannel no configuration (other than assigning the port to the channel) is done on the physical port. Everything is applied to the PortChannel interface.
Hope this helps you,
Don
