Warning message
ACL commands
Apr 23rd, 2003
I have a Pix 515e with 3 inter faces.
outside 206.135.121.3
inside 10.0.14.3
dmz 192.168.10.254
I would like to give a remote host 216.102.151.102 access to a server on the inside 10.0.102.5 using range 16151 -16241.
What are the commands I need to input for this to work?
vikrantarora Wed, 04/23/2003 - 13:58
Please follow these steps:
Step 1. Write the access list allowing tcp traffic. public_ip_assigned_to_server should be one of the IP's given by your ISP.
access-list acl_out permit tcp host 216.102.151.102 host public_ip_assigned_to_server range 16151 16241
Step 2. Apply the access-list to the incoming traffic on the outside interface
access-group acl_out in interface outside
Step 3. Inbound access is denied by default, so put in a static after defining an access list as done in Step 1 above.
static (inside,outside) public_ip_assigned_to_server 10.0.102.5 netmask 255.255.255.255
This should be all. Hope it works!
vik
