Preventing Multiple Logins from the same usernames
tepatel Fri, 04/25/2003 - 13:47
  • Cisco Employee,
I assume that you have Cisco Secure ACS as a AAA server. So under the user setup, you can configure "max-session" to 1 to limit the max session login from that user to 1. Also you can configure the same under group settings too.
Here is the link for that
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt30/user/o.htm#xtocid1043716
