Can't connect with anything later than VPN client 3.51???
admin_2
Level 3
Level 3
Can anyone tell me why the VPN client v3.5 works OK when I connect to our PIX (v6.31) but any later versions, including 3.6, 3.7 & 4.0 refuse to work and I receive the "peer not responding" error.
The password, group name and IP address are correct!
If I downgrade to 3.5 everything works again!!
Any help greatly appreciated.
Andy
pdentico
More than likely your isakmp policy is set to sha. Change it to md5 or add another with md5, and you should be ok.
pdentico
Not applicable
Sorted - I've just found it in an earlier post and everything is hunky dory now.
Thanks anyway.
Appreciated ;o)
