Lost connection to Catalyst 4006 - SUP3
Apr 28th, 2003
We lost connectivity to Catalyst 4006-SUP3 IOS 12.1-12c.EW1 and we got these errors messages when issued sh logg on cat 4006 (LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING is it a hardware or software problem??):
Log Buffer (4096 bytes):
PORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId3 on Switch Phyport 517,
count=933
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-3(
Gi3/17-24) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-1(
Gi3/1-8) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-2(
Gi3/9-16) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Nicer 2-4(G
i2/4,Gi2/6,Gi2/8,Gi2/10) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-6(
Gi3/41-48) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-5(
Gi3/33-40) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-4(
Gi3/25-32) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Nicer 2-3(G
i2/3,Gi2/5,Gi2/7,Gi2/9) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Nicer 2-6(G
i2/12,Gi2/14,Gi2/16,Gi2/18) - consecutive management requests timed out.
.Apr 28 00:46:13: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Nicer 2-5(G
i2/11,Gi2/13,Gi2/15,Gi2/17) - consecutive management requests timed out.
.Apr 28 00:47:23: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQI
d0 on Switch Phyport 513, count=1048
.Apr 28 00:47:28: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQI
d3 on Switch Phyport 519, count=1049
.Apr 28 00:47:43: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQI
d1 on Switch Phyport 514, count=1048
d1 on Switch Phyport 515, count=1048
.Apr 28 00:47:49: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQI
d3 on Switch Phyport 517, count=1049
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-2(
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-5(
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-4(
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-3(
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-1(
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Nicer 2-5(G
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Nicer 2-3(G
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Nicer 2-4(G
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Lemans 3-6(
.Apr 28 00:56:14: %C4K_LINECARDMGMTPROTOCOL-4-ONGOINGTIMEOUTWARNING: Nicer 2-6(G
.Apr 28 00:57:24: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQI
d0 on Switch Phyport 513, count=1165
.Apr 28 00:57:29: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQI
d3 on Switch Phyport 519, count=1166
.Apr 28 00:57:44: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQI
d1 on Switch Phyport 514, count=1165
d1 on Switch Phyport 515, count=1165
.Apr 28 00:57:49: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQI
d3 on Switch Phyport 517, count=1166
Prashanth Krishnappa Tue, 04/29/2003 - 03:59
  • Cisco Employee,
There were few bugs associated with similar problems. Try upgrading to 12.1(13)EW1
tmesbah Tue, 04/29/2003 - 06:07
Where can I found document that show this bug on our version and what is the stable version 12.1.(13)EW1 or 12.1.14E1(ED)
Very appreciate your help.
Prashanth Krishnappa Tue, 04/29/2003 - 06:15
  • Cisco Employee,
The bugs were internal and hence not on CCO. 12.1.14E1 has some changes in feature set. 12.1(13)EW1 should be good code to run. If you see this issue in 12.1(13)EW1, I suggest that you open a TAC case
DWAM_2 Tue, 04/29/2003 - 06:41
Hello
I don't understand why you ask to the customer to use the version
12.1.(13)EW1and not 12.1.14E1?
Like this url,
http://www.cisco.com/en/US/products/hw/switches/ps663/products_field_notice09186a008014ef30.shtml
"Cisco IOS Software Release 12.1(14)E1 contains only the software and hardware functionality up"
About the message guide signification,
here you can find the explication
http://www.cisco.com/en/US/products/hw/switches/ps663/products_system_message_guide_chapter09186a00800dea21.html
Best Regards.
Prashanth Krishnappa Tue, 04/29/2003 - 06:47
  • Cisco Employee,
Thanks for pointing that out. Upgrading to 12.1.14E1 from 12.1(12c)EW1 should be ok.(No features will be lost.)
tmesbah Tue, 04/29/2003 - 07:57
IEEE 802.3ad LACP is supported on 12.1(13)EW1 not in 12.1(14)E1
DWAM_2 Tue, 04/29/2003 - 08:12
So you have to verify yours functionnalities before upgrade :(
