Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919004members
1222970discussions
Community Activity
IPSec tunnel encrypt packts but no decrypt
Hi Community, We have a newly established IKEV 1 tunnel from Cisco ASA to AWS. This tunnel is currently at up state but the traffic is not passing through the tunnel. When we enter the show command "show crypto ipsec sa peer X.X.X.X" output have enca...
naveen98 by Level 1
  • 17 Views
  • 2 replies
sandbox and vpn issues
good afternoon,  I believe I have everything downloaded like I should have and I'm pretty sure that I've established a secure VPN with cisco. For some reason I cannot see this import button like on the instructions under lab topology. it says I have ...
RSP720-3C-GE in a CISCO7609-S chassis
I have no experience with this hardware and i can't get it to work. Booting an image lands me in rommon with the error message:Baseboard and rommon type mismatch. Rommon upgrade needed.%Software-forced reloadI switched over the MSFC4 to a RSP720-3C-1...
vermat51 by Level 1
  • 1 Views
  • 0 replies
Resolved! मनी फाइन कस्टमर केयर नंबर=8146587246=👈V⚡S👉🏿=9234661997 क्क अल्ल् म
मनी फाइन कस्टमर केयर नंबर=8146587246=VS=9234661997 क्क अल्ल् ममनी फाइन कस्टमर केयर नंबर=8146587246=VS=9234661997 क्क अल्ल् म मनी फाइन कस्टमर केयर नंबर=8146587246=VS=9234661997 क्क अल्ल् म
ISE admin Group AD users
I have created an external admin group in ISE, which is pointing to an AD group. There are several users in this AD group.Will all the users in this AD group gets ISE admin access or can it be restricted to few users.
manvik by Level 3
  • 65 Views
  • 2 replies
IOS Patch Image failed to be Installed.
Hello Team,I'm facing a challenge to apply a patch on the Cisco ISR4331. See the below error message from the router. SIMBA-RT#install add file bootflash:isr4300_cpld_update_v2.0.SPA.bin activate commitinstall_add_activate_commit: START Wed Mar 27 11...
dissai by Level 1
  • 88 Views
  • 4 replies
Resolved! Cannot access Web UI for Cisco 8500 WLC, only able to access IMM
Hello,I am trying to set up a cisco 8500 series WLC and am running into issues accessing the web UI. Here is a cisco link with the ports listed:https://www.cisco.com/c/en/us/td/docs/wireless/controller/8500/install/guide/ctrl8500.pdfWe have an ethern...
JTurn01 by Level 1
  • 129 Views
  • 3 replies
Tacacs server configuration problem
Greeting everyone! There is a little problem with configuring tacacs server on ws-2950-24 model switch. The rest switches we have are 2960 series, also 3xxx series and others, more modern versions. We always configured tacacs server this way:tacacs-s...
wrote a wrong UDI Product number for my booster license
hi, by mistake i wrote the UDI product and serial number the same by mistake  i need your helo to change the UDI product   PID                           SN                           UDI-----------------------------------------------------------------...
sakeral by Level 1
  • 35 Views
  • 0 replies
Resolved! AP出现downloading状态无法上线情况,求解啊
无线控制器WLC 5500的web 界面查看出现离线AP状态1台,目前WLC 5500无线控制器的软件版本为8.5.171.0并且该AP的Operational Status一直处于downloading无法上线状态,如下图所示:  查了一些链接信息:https://www.hello2099.com/2018.html 和 https://www.cisco.com/c/en/us/support/docs/field-notices/725/fn72524.html 还是没搞懂这AP无法上线...
FTD External Authentication Bugged???
Hi Community,I'm have an issue getting external authentication working on my FMC managed FTDs(firepower 2100s). I have configured the remote authentication server under in the FMC settings and then navigated over to platform settings to enable it on ...
Access Point
Hi all, can the cisco catalyst AP model 9136I, act as Autonomous.
RMA delivery for Singapore Site
Hi Cisco Team, Our Customer in indonesia have cisco devices installed in Singapore Site. Those devices using 8x5 nbd smartnet. Our question are: 1. If there is hardware failure the RMA part will be deliver dorect to singapore or to indonesia first? 2...
