Warning message
point to point T1 will not come up.
May 1st, 2003
We are upgrading from a 256k frame relay connection to a point to point T1. Router "A" is a 3620, Router "B" is is a 3660. Both are using T1-WIC-1-DSU cards. The original (frame relay) configurations are as follows:
Router A
interface Serial0/0
bandwidth 256
ip address 172.16.1.66 255.255.255.252
ip broadcast-address 172.16.1.67
ip directed-broadcast
encapsulation frame-relay
no fair-queue
service-module t1 timeslots 1-4
cdp enable
Router B
interface Serial1/0
bandwidth 256
ip address 172.16.1.65 255.255.255.252
cdp enable
For the T1 upgrade, I removed all frame relay specific configuration from the interfaces and added the following to both routers:
service-module t1 clock source line
service-module t1 timeslots 1-24 speed 64
service-module t1 framing esf
service-module t1 linecode b8zs
encapsulation ppp
I have alarm lights at both ends on the telcos equipment which does not go away regardless of whatever tweaking I try. A 'show service-module' issued on the routers shows the following:
Router A:
CO-ISDN#sh service-module
Module type is T1/fractional
Hardware revision is 0.96, Software revision is 0.2,
Image checksum is 0xED22BEC5, Protocol revision is 0.1
Transmitter is sending remote alarm.
Receiver has loss of signal, loss of frame,
Framing is ESF, Line Code is B8ZS, Current clock source is line,
Fraction has 24 timeslots (64 Kbits/sec each), Net bandwidth is 1536 Kbits/sec.
Last module self-test (done at startup): Passed
Last clearing of alarm counters 6d00h
loss of signal : 5, current duration 01:04:40
loss of frame : 6, current duration 01:04:40
AIS alarm : 0,
Remote alarm : 0,
Module access errors : 0,
Total Data (last 96 15 minute intervals):
255 Line Code Violations, 255 Path Code Violations
0 Slip Secs, 3795 Fr Loss Secs, 5 Line Err Secs, 2 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 3795 Unavail Secs
Data in current interval (79 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 79 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 79 Unavail Secs
Router B
Receiver has loss of frame, AIS alarm,
Last clearing of alarm counters 00:04:20
loss of signal : 0,
loss of frame : 1, current duration 00:04:11
AIS alarm : 1, current duration 00:04:11
Remote alarm : 0,
Total Data (last 0 15 minute intervals):
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in current interval (261 seconds elapsed):
0 Slip Secs, 261 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 261 Unavail Secs
I cleared the counters and put a loopback plug into each DSU, and the errors didn't come back. I will admit that I'm just using a straight through RJ-45 patch cord from the smart jack to the WIC instead of a 1,2,4,5 T1 patch. Also at the Router A end, the dmarc is extended about 100' from the smart jack and is only on CAT 3 cable. I am pulling a new wire in the morning, but it *is* the same line that the frame worked fine on for over two years. The telco (naturally) assures me that their equipment tests fine (What else would they say?). My question then is basically.....What have missed, or what should I try, so that I can positively rule this a telco issue?
Thank-you
mark-obrien Thu, 05/01/2003 - 18:17
  • Bronze, 100 points or more
Matthew,
Try putting loops toward the routers from the demarcs at each end and see if the alarms clear. If they do not, you have an internal cabling problem. Next, put loops towards the far end at each demarc, and see if, in either case, the alarms at the remote end clear. This will test the carrier's portion of the T1.
If your tests still indicate a carrier problem, point out to the telco that the loss-of-signal alarm means that the router is seeing NOTHING from the T1 line. Both routers, in response to the alarms they are receiving, are sending remote alarms. If the line was even half-way working, one end should see the remote alarm generated by the other.
Mark
matthew.hendrickson Fri, 05/02/2003 - 01:50
Is this just a matter of issuing 'loopback local' checking the errors, then 'loopback remote' and checking the errors? Or is there something more to it?
t.baranski Thu, 05/01/2003 - 18:32
Is the telco providing clocking on the circuit? If not, I think you'll need a 'service-module t1 clock source internal' on one of the routers.
matthew.hendrickson Fri, 05/02/2003 - 03:14
Thanks, I tried that. :)
I also tried inverting the data code, chaning the framing, changing the linecode, and everything else I could think of configuration related. I even changed the IP addresses to unnumbered just in case for some truly bizzare reason it didn't want to play nicely with the addresses assigned to the interface. Nothing helps-- the only thing that changes is that I lose the DS1 light on the telco's card when I alter the original configuration.
Georg Pauwen Fri, 05/02/2003 - 03:25
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
I had a similar problem once: not sure if you tried this yet, but you could change the encapsulation from PPP to HDLC and then back, that worked for me (I guess the line had te renegotiate all the PPP parameters).
Georg
bcbvale Fri, 05/02/2003 - 11:25
Try rolling the pairs in the cable(or jack).
This happens to me occasionally where the telco has the pairs rolled so that if you insert the cable into your router you get no carrier, nothing. But if you put a loopback plug into the jack and have the carrier test it comes back clean.
ChrisV
matthew.hendrickson Sat, 05/03/2003 - 15:06
It works now.
It was a combination of two things:
1) Pulling a new wire for the extended dmarc got the "loss of signal" errors to go away so I could see alarms on the line.
2) changing the encapsulation to hdlc and back to ppp finally ended up doing the trick!
Thanks to all
