Warning message
broadcast suppression on catalyst 6000
May 2nd, 2003
The port based broadcast suppression command on Catalyst 6000 CatOS provides a keyword " UNICAST".
C6506 (enable) set port broadcast 1/1 1% ?
multicast Enable/disable multicast suppression
unicast Enable/disable unicast suppression
<cr>
Can anyone knows if the keyword " unicast" is related to " unknow unicast " limiting the unicast flooding or It's related to all unicast traffic on that port ? ( the configuration guide and the command reference guide are not clear about that )
TIA
owillins Thu, 05/08/2003 - 06:43
  • Silver, 250 points or more
My guess is that it refers to all unicast traffic on that port. See the last example in the reference below.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_7_2/cmd_ref/set_po_r.htm#28114
Also note that Broadcast suppression is used to limit the broadcast traffic during a broadcast storm caused by a spanning tree loop. Please be careful when you use this feature for any other reason.
