Warning message
Signature tuning in 4.0
May 3rd, 2003
It is very time consuming to locate the particular signature in v4.0 using
Configuration->Sensing Engine->Virtual Sensor Configuration->Signature Configuration Mode..
Page by page is not the best way to navigate.
Is anyway to enter the enter the specific sig. # to edit or have the same navigation as in v3.x using signature ranges for every page?
Overall Rating: 3 (1 ratings)
kleem Mon, 05/05/2003 - 06:40
  • Cisco Employee,
The signature range information (as it was in 3.1) will be included in the next CIDS release (4.1) to make it easier to locate signatures.
DSmirnov Mon, 05/05/2003 - 15:47
Thanks a lot,
is ETA available for 4.1?
Another pain with 4.0 - it takes 2-3 mins for me to open "Signature Configuration Mode" on loaded sensor.
Plus I can't disable more then one signature at them time. I have the following message during the attempt to Save Changes:
Update failed [Invalid configuration. Restarting the Virtual Sensor .... This may take some time .... ]
I need to logout and login back to disable another signature.
IDS version 4.0.2S43.
