Warning message
Load balacing among multiple equal paths from Catalyst 4000
May 5th, 2003
We have a two catalyst 4000 IOS ver 12.1(8a) connected to two 7204 router. The two routers and switches are connected in a full mesh configuration. To reach a destination x.x.x.x I can see four equal cost paths in the switch routing table. Now how can I do a load sharing/balacing among these four paths so that all the four paths are utilised efficiently. I am running OSPF in my catalyst switch. The two routers are running EIGRP.
Does it help if I configure CEF?
Thanks and Best Regards,
Raj.
Gilles Dufour Mon, 05/05/2003 - 13:57
  • Cisco Employee,
if you see 4 routes for each destination it means the router is already loadbalancing the traffic.
Enabling CEF will just help you select what type of loadbalancing you want.
We have per-packet or per-destination.
The command is 'ip load [per-packet|per-destination]'
Gilles.
asrkumar Mon, 05/05/2003 - 17:55
Hi Giles,
Thanks for the info. Just to clarify some points.
I had that in my mind what you said "ip load [per-packet|per-destination]". I read a cisco doc which says perpacket load balancing is not possible in L3 switching. So does catalyst 4000 support per packet load balancing.
The reason I ask this because we have two links connected to two routers for destination X. I find all the traffic is passing via link-1. But link-2 is under utilized, I want to share the load across the two links.
I have captured the route for one particular subnet from both the switches.
Switch-1>sh ip rou 10.192.0.0 255.255.0.0
Routing entry for 10.192.0.0/16
Known via "ospf 123", distance 110, metric 20
Tag 888, type extern 2, forward metric 1
Last update from 10.197.1.18 on Vlan6, 4d08h ago
Routing Descriptor Blocks:
10.197.1.10, from 192.168.197.18, 4d08h ago, via Vlan5
Route metric is 20, traffic share count is 1
* 10.197.1.18, from 192.168.197.18, 4d08h ago, via Vlan6
10.197.1.9, from 192.168.201.13, 4d08h ago, via Vlan5
10.197.1.17, from 192.168.201.13, 4d08h ago, via Vlan6
switch-2>sh ip rou 10.192.0.0 255.255.0.0
From the route statements we see both the active routes point to the Vlan6. Is it possible to have each switches goes to different vlans (5 &6).
If I configure Ip load per packet does it help? I guess I can configure this only on Vlan interface level. So do I have to configure for all Vlan's.
Thanks for your comments.
Best Regards,
Raj.
clayton-price Mon, 07/21/2003 - 12:47
We are having the same problem with our 4006 switches w/ the layer 3 card. We see 4 equal cost routes(2 ethernets per router), however one router gets considerably more traffic than the other. We are currently doing process switching with the no ip route-cache.
