Warning message
VPN3005 and C837; How to connect for ever?
May 5th, 2003
Hi, I have a Cisco VPN 3005 and I have users with Cisco 837 routers. Is there a way to configure the C837 to be always VPN’ed into the main site. At this current time users have to go to a URL on the router and log in and then after 8 hours get disconnected (Bit of an problem when you got an IP Phone on the plugged in).
Thanks for your help
zahmed Mon, 05/05/2003 - 18:56
  • Cisco Employee,
You already seem to have everything in place correctly. Just take a look at the idle timeout configuration on both ends. Increase that to bigger value(s) according to your needs and you should be all set as you want to be.
~Zulfi
