Warning message
FWSM question
May 6th, 2003
  • Bronze, 100 points or more
Hi!
Is MSFC required if CatOS is run on the Supervisor?
According to docs FWSM runs its own routing and from FWSM point of view
MSFC is just an external router. Right? So, can external router be used instead
of MSFC?
Oleg Tipisov,
REDCENTER,
Moscow
Prashanth Krishnappa Tue, 05/06/2003 - 04:05
  • Cisco Employee,
MSFC is not mandatory but preferable due to better performance due to MLS/CEF compared to an external router
ovt@redcenter.ru Tue, 05/06/2003 - 23:11
Just to understand this better: Is that correct that SVI (FWSM-to-MSFC-or-other-router VLAN) is needed to only exchange routing updates between MSFC and
FWSM and FWSM forwarding decisions are completely independent of MSFC?
The SVI VLAN should be the only VLAN common to both FWSM and MSFC
unless CatOS 7.6 is used that supports multiple SVIs. Correct?
Oleg Tipisov,
REDCENTER
