RTM - Cat 4006 Sup II
May 6th, 2003
Just installing RTM in our lab. I've enabled RMON on my CAT 4006 Sup II CatOS 7.3.
I've added the switch to the RTM Server but I have problems with monitoring it's traffic.
When I try to check statistics in the Traffic Monitor all, but 'TopN Links' options are grayed (disabled).
What should I do to get access to statistics like 'data link layer' statistics?
The switch is in ACTIVE state in the Server.
Thanks for the help,
Attila
rmushtaq Tue, 05/06/2003 - 07:33
  • Blue, 1500 points or more
Is this RTM 1.4?. Without a Probe/NAM, you'll only get Data Link Layer stats. Are you seeing the Data Link Layer graphs in Traffic Monitor?
adancso Tue, 05/06/2003 - 08:01
After restarting the server everything is normal.
(It's strange, because I already restarted it before couple of times.)
Thanks for your time.
Attila
