05-06-2003 09:32 AM - edited 03-18-2019 02:40 PM
Scenario:
Unity does a supervised transfer to an extension that is busy. Call handler is setup to automatically place caller on hold. After the first 30 seconds, the caller is prompted to continue holding, leave a message or try a different extension. Caller sits dumbfounded on the phone, confused by the slightest chance that they would actually have to provide some sort of feedback.
Question:
Can I control where Unity directs callers if they are too lame to press a key after that prompt?? They are currently being sent to the opening greeting.
Thanks alot!
-Dennis
Solved! Go to Solution.
05-06-2003 01:11 PM
Currently that's not configurable - it's hard coded to go to the opening greeting handler created by setup. The original idea was to start the process of backing out and eventually hanging up on a call that may have disconnected without us getting a signal as such (a problem on some older PBXes out there in the past, not something that happens a heck of a lot these days).
05-06-2003 01:11 PM
06-05-2003 07:10 AM
is this changed in 4.0.2 or is it still not configurable ?
06-05-2003 08:15 AM
Not currently - we added control for subscriber exit points and more control for exits off of name lookup handlers and the like but the hold queue is still hard coded at this point.
I'll check with the conversations guys and see if this is on their queue somewhere.
06-05-2003 11:23 AM
Chatted with the conversations guys and you may be in luck here. There's a undocumented registry setting that will allow you to change which call handler we send calls to on a system wide basis - by default it'll go to the opening greeting call handler but you can change this to be any call handler in the system.
There is a registry key that be used to work this -
HKLM\Software\Active Voice\Conversations\1.0\Phone Transfer\CallHoldingXferTo
It is a string and you will need to have the alias of the handler that we want to send the call to.
Yeah, this is system wide which I suspect you don't want - I'm guessing you want this configurable on a per handler basis such that it can loop back to the same handler instead and do a "hands free" holding scheme.
03-24-2004 02:10 PM
Jeff, I realize I'm replying to a post almost a year old, but I'm running into the same problem here and would like to know if there is a configurable method for this yet. I'm in a multi-tenant scenario, and this feature can't possibly be used by more than one tenant's call Handler unless we have the ablility to change this on a per-handler basis. Thanks in advance.
03-24-2004 02:50 PM
No, there's been no changes in this regard since then - there's been no requests added to the PERs database for this type of thing so the product folks haven't had this on the list of items for the engineering folks to work on. The best I can suggest is to get your account team to put in a PER for it...
