Warning message
PIX 525 Ver. 6.3(1) & static IP problems
Answered Question
I'm having problems changing static IP addresses to internal IP addresses.
The original statement looked like this,
static (DMZ,outside) xxx.xxx.46.3 192.168.1.2 netmask 255.255.255.255 0 0
When I change the external ip address to point to another internal IP address,
static (DMZ,outside) xxx.xxx.46.3 192.168.1.3 netmask 255.255.255.255 0 0
the new address is listed but the external ip address still points to the old internal address. I can't correct the problem until I reboot the PIX.
Is this some sort of a cache problem.
Correct Answer by rpel about 14 years 3 months ago
Martin,
Do you have a chance to implent the logical interface (virtual interface) ?
As you can see, 6.2(2) pix does not support virtual interface; however, 6.3(1) does. To answer your question, after you did the configuration, you must use
clear xlate command to clear all translations. I hope this would help you.
Overall Rating: 5 (1 ratings)
Correct Answer
rpel Thu, 05/08/2003 - 11:45
Martin,
