Warning message
saving a config in other than .csv format
May 9th, 2003
We are using the CWLMS 2.1 in our Cat 5000 environment and I am looking to create a repository for all the switches configs in case the CWLMS 2.1 is out of the water since the format in which the CWLMS 2.1 is CSV and can't be read with a regular text editor. Is there any way to store these configs in the CWLMS 2.1 in any formats other than CSV?
Thanks.
_ Alex
rmushtaq Fri, 05/09/2003 - 12:39
  • Blue, 1500 points or more
Alternate option could be to use the Data Extracting Engine (DEE) which is a utility that you can install on RME 3.4. It extracts data for devices managed by RME 3.4 from the RME inventory database and configuration archive in the required XML format.
DEE 2.0 provides two mechanisms to extract data - A command line utility and a servlet utility, which can be accessed by any client script through HTTP or HTTPS. For more information regarding DEE 2.0 and for developer's reference, refer to the online help.
