Warning message
Updating CM from 3.2.2 to 3.2.3 causes IPAA (IVR) to Fail
May 11th, 2003
It happened again... After Updating the Callmanager I get "all sorts of errormessages" when I open the Webpage of the IVR Application engine.
This time it is:
AvvidProcCtl.AvvidProcCtl.1 error '80004005'
QueryServiceConfig failed (1783): The stub received bad data.
/AppAdmin/MainMenu.asp, line 150
The New JTAPI is installed on the machine, and I'm out of ideas (sunday evening at 2200......)
Would be grateful if anyone could help
Greetings
Jarle
jbayuka Fri, 05/16/2003 - 07:19
  • Bronze, 100 points or more
Check that you do not have the Q274450 MS Hotfix installed. If so unistall this and try again. This Hotfix is known to cause this problem.
