Warning message
Demand Circuit in OSPF Virtual Link
May 11th, 2003
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
I am trying to configure an OSPF Demand Circuit between three areas connected by a virtual link. Here is the setup:
R1 (area 2) -- R2 (Area 1 Area 2) -- R3 (area 2 Area 0) -- R4 (area 0).
The virtual link is between R2 and R3. The ISDN runs between R1 and R4. My question is: when I put the network of the Dialer interfaces on R1 and R4 into OSPF, which area do they have to be part of ? Or is it a limitation of the OSPF Demand Circuit that it cannot span areas ? After all, the same network cannot be part of two areas.
Thanks for your help in advance.
Georg
cymurai Mon, 05/12/2003 - 14:17
Although I am not familiar with the rest of your network, I don’t see why you have a virtual-link between area2 and area0? I would make R1 and R2 both members in area2 then make area2 totally stubby. The WAN interfaces of R3/R4 would also be in area2, making the LAN interfaces of R3/R4 in area0 (this would make R3/R4 both ABRs). You could then make both WAN links demand-circuit. You don’t mention if ISDN is for backup only or will be used some other way.
Hope this link helps!
http://www.cisco.com/warp/public/104/23.html
