Fixed IP Address connecting using VPN Client
Answered Question
May 12th, 2003
Hi everbody. I am using a VPN Client when I estabilish a VPN Tunnel with a 1600 Router, and I have a question.
Can I assign a Fixed IP address in client, instead the router send to client random addresses?
Can I it would make this??
It would be in VPN client configuration, or in router configuration?
If yes, as I make this?
Do I need other tool, or another software or hardware to do this???
any help is hope..
thanx....
Correct Answer by jfrahim about 14 years 3 months ago
I don't think there is an easy way to accomplish this.
However, if you create a different groupname for the user who needs a static ip address, I think you should be good to go
So what you need to do is, create a new pool of addresses. Make the start and stop ip address to be the same ( this is the address that you would want to assign to the VPN user)
Configure another ipsec group on the router, and link the new pool to this group
Have your VPN client connect to this group
Hope that helps
Jazib
Overall Rating: 5 (1 ratings)
Correct Answer
jfrahim Mon, 05/12/2003 - 09:32
  • Cisco Employee,
Hope that helps
Jazib
rsoave Tue, 05/13/2003 - 09:37
Thanx Jazib, its help me so much.
This was really a easy solution.
Best Regards, God bless you..
