Warning message
calls getting stuck
May 12th, 2003
I have ccm 3.1(4b) spd. I have two lines on each phone with call waiting ON. Sometimes the calls gets stuck if another calls answered in the call waiting. If the user come back to the first one they cannot do anything with the first call. The call wont be dropped. You have to unplug the phone and plug it back. Phone load is P00303010413 on 7960 and 7940's. Do anybosy know this why thanks in advance.
oodunuga Mon, 05/12/2003 - 17:05
I think you might be hiiting bugs
CSCdz12960 Phone locks up when answering call in certain scenario a duplicate of
CSCdy28570 Phone Hangs When User Mistakenly Hits 2nd Line For Pickup found in 3.1.4a.
This as however been verfied and integrated in 03.2(02C)SPG 003.003(002.010) 03.2(02)ES38 003.002(002.005) 003.003(001.030) 003.004(000.025)
Hope it helps
Tola.
scottiptel Mon, 05/12/2003 - 17:17
Bunch Of thanks Tola, What is a work around for this problem. Upgradation to any specific version??
oodunuga Tue, 05/13/2003 - 09:09
If you're considering an upgrade then I would suggest to go to 3.3.2 SPC
Hope it helps
Tola.
