Warning message
Coo\mmitted Access Rate statistics
Answered Question
May 12th, 2003
I have next:
2610#sh run int s0/0.1
Building configuration...
Current configuration : 457 bytes
interface Serial0/0.1 multipoint
description Internet access
ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
ip access-group 100 in
ip access-group 101 out
rate-limit input access-group 110 256000 48000 96000 conform-action set-prec-transmit 6 exceed-action set-prec-transmit 1
rate-limit input 192000 36000 72000 conform-action set-prec-transmit 2 exceed-action drop
no ip route-cache
no ip mroute-cache
frame-relay map ip xxx.xxx.xxx.xxx 100 CISCO
end
2610#sh int s0/0.1 rate-limit
Serial0/0.1 Internet access
Input
matches: access-group 110
params: 256000 bps, 48000 limit, 96000 extended limit
conformed 66863 packets, 54304981 bytes; action: set-prec-transmit 6
exceeded 34944 packets, 38128240 bytes; action: set-prec-transmit 1
last packet: 40ms ago, current burst: 73052 bytes
last cleared 12:20:46 ago, conformed 9000 bps, exceeded 6000 bps
matches: all traffic
params: 192000 bps, 36000 limit, 72000 extended limit
conformed 522977 packets, 269025441 bytes; action: set-prec-transmit 2
exceeded 42175 packets, 33584565 bytes; action: drop
last packet: 28ms ago, current burst: 40 bytes
last cleared 12:19:34 ago, conformed 48000 bps, exceeded 6000 bps
I don't understand -why for matches: access-group 110 i have only conformed 9000 bps, exceeded 6000 bps (i think must be near params: 256000 bps)
and
for matches: all traffic - conformed 48000 bps, exceeded 6000 bps ( may be params: 192000 bps)?
Correct Answer by ivillegas about 14 years 3 months ago
Show Interfaces Rate-Limit Field Descriptions
Field Description
Input These rate limits apply to packets received by the interface.
matches Packets that match this rate limit.
params Parameters for this rate limit, as configured by the rate-limit command.
bps Average rate in bits per second.
limit Normal burst size in bytes.
extended limit Excess burst size in bytes.
conformed Number of packets that have conformed with the rate limit.
action Conform action.
exceeded Number of packets that have exceeded the rate limit.
action Exceed action.
last packet Time since the last packet in milliseconds.
current burst Instantaneous burst size at the current time.
last cleared Time since the burst counter was set back to zero by the clear
counters command.
conformed Number of packets conforming since the counter last cleared with
the clear counters command.
exceeded Number of packets exceeding since the counter last cleared with
Output These rate limits apply to packets sent by the interface.
The drops you encountered are interface drops and should not be the same as the CAR dropped packets.
The conform numbers should add up to the total bytes transmitted that match the policy set and the excess that is defined.
Overall Rating: 3 (1 ratings)
Correct Answer
ivillegas Wed, 05/21/2003 - 07:17
  • Silver, 250 points or more
Field Description
counters command.
