Warning message
Router to router VPN
May 13th, 2003
Hi Guys.
we are having one location in USA and one in India.We are taking a data link between these two lines and want to set up VPN Between the two.
i m having 7206 Router and also 2621 router at both the sites.Can i use router to router VPN.Means can i use VPN Between these two router.
Please explain in detail,ny document that explains will be very helpful
Dinesh
Overall Rating: 5 (1 ratings)
dinesh_ymca Wed, 05/14/2003 - 11:01
thx a lot.
one more doubt.I m using the same two 7206 routers between the two sites for IPLC `s which asre forwarding my voice traffci between the two locations.I want to use the same 7206 VXR Routers at the two locations for VPN.
If i donot use any hardware module.Is it going to cause abny issues.
And what IOS version should i have on my routers.
Dinesh
jfrahim Wed, 05/14/2003 - 13:11
  • Cisco Employee,
Hi there,
Voice traffic is time sensitive. Having a router without an encryption module would add considerable delay when the packet gets encrypted. I guess, it really depends on you how much delay you can tolerate. You can look at the V3PN design guide for different scenarios and IOS recommendation etc
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns241/c649/ccmigration_09186a0080146c8e.pdf
Jazib
dinesh_ymca Wed, 05/14/2003 - 16:54
Thx.
now senario is a lot more clear to me.
one last query.
i m using c7200-is-mz.122-10 and c7200-kboot-mz.122-12b.bin
and crypto commands are not working on my router.
like
crypto isakmp policy 1
should i need to upgrade my router IOS.i also tried to find out using cisco software adviser but could not find any satisfactory answer.
Please tell what to do.
Dinesh
