Warning message
ISDN Router config check, please comment.
Answered Question
May 14th, 2003
I've had a couple of goes at getting this config correct and am running out of chances. Before I test this in the real world, I'd appreciate it if someone could tell me whether this looks as though it will work.
It is an ISDN hub router simply receiving calls from ISDN spoke routers and passing on the authentication to a Radius server. I am interested in any suggestions, but especially whether the dialer/serial int config is correct.
Dean.
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname mel04
logging rate-limit console 10 except errors
aaa new-model
aaa authentication login default group radius
aaa authentication login NO_RADIUS local
aaa authentication ppp default group radius
aaa authorization exec default group radius
aaa authorization exec NO_RADIUS local
aaa authorization network default local group radius
aaa accounting send stop-record authentication failure
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
enable password 7 045E1B570C345E4B
username root password 7 151C0E07102B39
ip subnet-zero
no ip finger
no ip domain-lookup
ip name-server 202.81.96.82
isdn switch-type primary-net5
controller E1 1/0
pri-group timeslots 1-31
interface Ethernet0/0
description Connected to HP Switch on mel04 VLAN
ip address 202.81.105.66 255.255.255.252
full-duplex
interface Ethernet0/1
no ip address
shutdown
half-duplex
interface Serial1/0:15
no ip address
dialer rotary-group 1
isdn T310 30000
no cdp enable
interface Dialer0
no ip address
no cdp enable
interface Dialer1
description connected to dial in PCs(ISDN)
no ip address
encapsulation ppp
no ip split-horizon
dialer in-band
dialer-group 1
peer default ip address pool mel04-Group-1
ppp authentication chap pap callin
ppp multilink
ip local pool mel04-Group-1 203.81.106.1 203.81.106.30
ip classless
ip default-network 202.81.105.0
ip route 0.0.0.0 0.0.0.0 202.81.105.65
ip http server
snmp-server community public RO
snmp-server location Richmond
radius-server host 202.81.96.93 auth-port 1645 acct-port 1646 key 7 050C051B285F
5E
radius-server retransmit 3
line con 0
exec-timeout 0 0
password 7 11071C0E031319
transport input none
line aux 0
line vty 0 4
password 7 06080A2A584F1B
login authentication NO_RADIUS
no scheduler allocate
end
mel04#
Correct Answer by mark-obrien about 14 years 3 months ago
You need to assign an IP address to the Dialer 1 interface. Also, make sure other routers on your network know how to reach the addresses in your pool, mel04-Group-1.
Mark
Overall Rating: 5 (1 ratings)
jasyoung Wed, 05/14/2003 - 12:18
  • Gold, 750 points or more
Some notes:
You should have an IP address on the Dialer1 interface. Setting it to "ip unnumbered Ethernet0/0" is acceptable as well.
Consider setting 'ppp multilink bap' to support dynamically adding and removing a second channel for clients that support BAP.
You probably need something like "dialer-list 1 protocol ip permit" or "dialer-list 1 protocol ip list [an access list]" in order to pass any IP traffic on that interface.
If it doesn't work after changing the above, we'll need to know exactly what happens when you try. Include the output of "debug aaa authentication", "debug aaa authorization", and "debug ppp negotiation".
ddnicholls Wed, 05/14/2003 - 14:25
Thanks very much guys, much appreciated, will let you know how it goes.
Dean
Correct Answer
mark-obrien Wed, 05/14/2003 - 12:20
  • Bronze, 100 points or more
Mark
