Warning message
Management of MGX 8800s
May 20th, 2003
I have a small network of 4 MGX8830/8850 (PXM1E). The atm0 addresses are all in a 200.200.200.0/24 subnet, but each has its lnPci0 address in a different 10.x.x.x/24 network. I have a CWM on the same 10.x.x.x subnet as one of the MGX8830s which is to monitor all the MGXs. This MGX8830 also has an RPM-PR.
Could somebody help point me in the right direction on how to set the management of these up, (i.e. arp server config on the RPM, whether I need to consider a different config approach), as I do not seem to be able to get any devices leant on the CWM, and I need to be able to telnet to each box from any location.
s/w versions in use are 4.0.0.200 on the PXM1E
12.0 for CWM.
12.11T on the RPM
Many thanks
