Warning message
3Des configuration on C1710
May 20th, 2003
There is the configuration of 3Des with another C1710
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp key ***Key*** address <Remote Router>
crypto ipsec transform-set cm-transformset-1 ah-sha-hmac esp-3des
crypto map cm-cryptomap local-address Dialer1
crypto map cm-cryptomap 1 ipsec-isakmp
! Incomplete
set peer <Remote Router>
set transform-set cm-transformset-1
match address 100
On the above configuration, you will see the ! Incomplete message. Do you know what is missing? In addition, I cannot connect to the remote router. I just follow the sample configuration. Please advice. Thanks
Godwin
mpedro Tue, 05/20/2003 - 10:06
Do you have a ACL 100
Since it is defined in your crypto map, you need to make sure you have a ACL 100
godlam Tue, 05/20/2003 - 20:25
yes, you right. I miss the ACL 100 but when I put back the ACL 100, the router is hang. There is the ACL statement
access-list 100 permit ip 202.x.x.x 0.0.0.3 203.x.x.x 0.0.0.15
Thx
Godwin
