Problem to reset 1200-AccessPoint to its default user and password
May 22nd, 2003
Many times i tried now to reset the Access point to its default parameters.
I fallowed precisely the users manually But it doesn't work. The Accesspoint
ist still set by the last changes, because the SSID is alway the same and not the standard SSID
So i can't configure it because i don't know the password which was set by the last administrator.
The Accespoints Firmware is vers. 11.40 T.
Does anybody have an idea?
rburkhard Fri, 05/23/2003 - 01:32
Hi Pedro,
I have same problems and hope we will get an answer today, otherwise I will sent the Accesspoint back to cisco (It is a new device from cisco...)
Version is 12.2(8).
Ruedi
rburkhard Fri, 05/23/2003 - 06:09
Hi Pedro,
I couldn't set to defaults, but I found the (default) password. It is Cisco, with a uppercase C at the begin, not as usual all letters lowercase!
Maybe it helps you.
Ruedi
El_Pedro Fri, 05/23/2003 - 06:43
Yes, I know,
I have found it in the manuals too. But no success. Always the same message...
I hope sombody can help us.
Pedro
derwin Sun, 05/25/2003 - 18:31
  • Cisco Employee,
Pedro, With the firmware version 11.40 there was problem with the reset. CSCdy60114
The only way around this is to use the "old " method for a password recovery
Follow the steps here for a pre 11.07 firmware
http://www.cisco.com/warp/public/102/wlan/pwrec-2.html
MAKE SURE YOU FOLLOW STEP BY STEP OR YOU MAY RENDER YOU ACCESS POINT UNSERVICEABLE AND WILL NEED TO BE SENT TO THE FACTORY FOR REPAIR.
If after reading this you are not clear on any of the steps please contact the TAC as if you make a mistake the only way to reapir it is via an RMA
Firmware versions newer than 11.50 do not have this problem and once you have recovered the passowrd then I recommend that you upgradeto the latest firmware version to avoid it in the furture
Anonymous (not verified) Fri, 05/30/2003 - 04:45
Make sure you are logged in as "Administrator" on the workstation, you cannot access most features logged in as a user with admin privlidges.
Paul.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
