trouble updating service pack on IDS MC
Answered Question
May 22nd, 2003
I've just updated to version 4.0 and installed the latest software for IDS MC ver 1.1.1. I can not get the MC or sensors to upgrade to the latest service packs.
in Configuration->Updates->Update Network IDS Signatures, I choose IDS-K9-sp-4.0-2-S42.zip and click apply.
I recieve the following message:
Apply the IDS-K9-sp-4.0-2-S42.zip update to the Management Center.
Then I click Finish.
Imediately after that it bings me back to the apply button without having made any changes. Ive checked the Audit Log and nothing shows in there as well.
Ive also tried updating a test sensor I have, and it seems to skip step 2 (asking for passwd) and results in the same.
Any Ideas/hints would be appreciated...
Thanks.
Shawn
Correct Answer by ywadhavk about 14 years 3 months ago
Well, next, I would delete the sensor and add it back in just to check and restart the connectivity and try the same update.
thanks,
Yatin
Overall Rating: 5 (1 ratings)
ywadhavk Thu, 05/22/2003 - 20:22
  • Cisco Employee,
Please check the connection to the sensor by going to IDSMC-->Device--->Settings--->select the sensor in Object Selector, and Query the sensor. The screen should refresh and bring up the sensor details. Not prompting for the password seems to be normal. How much time did you wait after applying the SP and checking for the update? It takes about 10-15 mints on normal network loads.
yatin
shawn.posthumus Fri, 05/23/2003 - 05:44
There is some information in the Audit Log this morning..
The update package provided appears to be corrupt, or permission was denied for reading the file. Please verify the update package contents and retry the operation.
I downloaded the zip again to make sure it wasnt corrupted, and am seeing the same results. I have it in the correct folder and there should not be any issues in reading the file.
Correct Answer
ywadhavk Fri, 05/23/2003 - 07:32
  • Cisco Employee,
thanks,
Yatin
