Warning message
PIX 6.3(1) Console Lockup
May 23rd, 2003
Has anyone experienced problems with the console connection to a PIX running version 6.3(1) freezing on them? I have two PIXs running 6.3(1) that will intermittently freeze the console connection on me.
drolemc Thu, 05/29/2003 - 11:44
  • Silver, 250 points or more
If I remember correctly, there was a problem with the Console hanging under certain situations such as after write mem or with syslog configured. However, these problems were seen in older versions of the PIX OS and I did not see a similar problem documented for 6.3(1). Your problem might simply be due to your PIX being overloaded. You could also check your console speed settings.
