Warning message
uBR924 configuration
May 24th, 2003
I just installed a Cisco uBR924 Cable Access router at my home. I just finished the first four the CCNA course and found it very helpful in setting it up. Even though I was able to get it working I'm still not comfortable with its security. If anyone has any experience with this router please let me know how I can configure the cable port to accept the IP address from the ISP and allow me to configure a static address on the ethernet ports. I'd like to use NAT if possible. I've downloaded the guide from the Cisco site but it really doesn't help me. If anyone has any configurations on this router please fill free to email them in text form to strammell@sc.rr.com.
Stuart Trammell
jbayuka Thu, 05/29/2003 - 11:53
  • Bronze, 100 points or more
I am sure this document will help you in finding the info that you need now
http://www.cisco.com/en/US/tech/tk86/tk89/technologies_configuration_example09186a0080093fc6.shtml
but as you are new to this product, I would also suggest you to take a look at http://www.cisco.com/en/US/products/hw/cable/ps2221/prod_configuration_examples_list.html
for various other configuration tips that you may require in the future
