SSH across an IPSEC tunnel
May 26th, 2003
I have a client who requires to run SSH sessions across an ipsec tunnel running between an 827 ios and a pix 506.
All NAT/ networking is ok as pings between the servers /networks are fine.
(as are all the current applications)
SSH from the PIX internal network to the 827 internal network fails.
Strangely SSH from the 827 internal network t the pix internal network works fine.
Does any one have any ideas?
The pix is version 6.1(4) and the IOS is 12.2.8
a.rajaram Tue, 06/03/2003 - 01:29
CSCdw29965 - SSH:Watchdog timeout if receiving huge SSH packets might be the cause for the Issue "SSH from the PIX internal network to the 827 internal network failing"
Aarthi.
a.rajaram Tue, 06/03/2003 - 01:31
CSCdw51492 - ssh to pix will drop ping packets going across pix.
check this out too
Aarthi.
