Warning message
ISDN without multlink PPP
May 26th, 2003
Without Multilink PPP how is the traffic shared between a few B channels ?
Can I share the traffic on these channels on a packet basis ? Can I get a full 512 k for example for a ftp tranfer ? Or Can I get only 64 k ?
Thanks in advance
lgijssel Tue, 05/27/2003 - 00:30
  • Red, 2250 points or more
In theory, you can achieve load balancing while you have mutiple equal-cost paths. This will depend on your configuration. EIGRP or OSPF could be used to automate the load-balancing.
On a DDR-ISDN this will mean that your lines are always up. This is not desirable in most situations due to the high costs involved.
Except from the money, there is little that stops you from doing this.
One more advice: It is often cheaper to have a line open for a long period of time than to have your B-channels toggling al the time.
Leo
guyber Tue, 05/27/2003 - 00:52
Thanks for your answer.
Please is it possible to share the packets (round robin basis) on the B-channels without MLPP ? Or is it necessary to aplly MLPPP ?
tepatel Wed, 05/28/2003 - 09:08
  • Cisco Employee,
YES.. if the next hop for both the b channels is the same and also the cost of both the path. That way we have a two equal cost routes for the same destination.
MLPPP will only buy you the "Fragmentation" of the packets. If no mlppp, the equal cost links will be used for load balabce of the packets (but will not be fragmented).
