Warning message
Fax Over H323 To Unity 4.0 - exchange
May 27th, 2003
Hello
The system's that involved in the problem that i have are :
1. C2600 Software (C2600-IS-M), Version 12.2(11)T6 as the Prime Voice gateway Configured as a H323 GW
2. CCM ver 3.3
3.Unity 4.0 + Cisco Unity IPfax
I've configured all of the necessary step's actually the CCM is not involved in the process,
The fax should transfer directly to the Inbox as a tiff file, meaning :
1. install the IPfax On the unity
2. Build & conf the IPFaxRecieved etc.
3. and then try to work around the H323 GW trough out the Cisco Doc. about
T37 T38 Fax Pass trough
probably I've forgot have a mistake some where, otherwise i wouldn't got so far
i would very much appreciate any help from someone who've been there already
thanks
Ofer Eliel
Integrated Technology Services
IBM Global Services, Israel
E_mail: [email protected]
Tel: 972-3-9188447
trailman73 Tue, 05/27/2003 - 05:43
  • Bronze, 100 points or more
I am using the Third part fax tool from answermonkey.net. You recieve the fax on the router, call the appropriate on-ramp and off-ramp scripts. It is converted and sent to the ipfax client on unity. The fax is matched up to the DID number in the header and sent to exchange. Are you using DID? What are the debugs giving you?
Geoff
o.eliel Wed, 05/28/2003 - 07:05
Hello Geoff
Thanks , I'm not working with DID , the IPFax software instruct me to install
in the following ways :
dial-peer voice 2 mmoip
 application fax_on_vfc_onramp_app out-bound
 destination-pattern 9913061     <== the company's fax number; must match destination pattern of mmoip peer
 information-type fax
 session target mailto:[email protected]  <==the mailbox set up for inbound fax messages
the other option is indeed working with DID to a port, but in this option i
can't give a session target mailto: since it is a POTS Dial-peer
I'm steal stuck on the router(voice gateway) with out actually send it to the
mail box or Unity machine
thanks again for your reply
B.R.
and I'm waiting for help :)
Ofer
