Warning message
X25 Timeouts
May 27th, 2003
I use 2600's as x25 pads and I have a problem with virtual connections, my customers telnet to the port numbers get allocated a virtual connection which is correct, however the issue I have is they hold on to that connection for day's without sending any data eventually they use all 128 connections and the router stops.. does anyone know of a timeout or other config I can use that will disconnect the client after a few secs / mins if they fail to send data.
Many thanks is advance
gmarogi Mon, 06/02/2003 - 06:54
  • Bronze, 100 points or more
There seems to be a command 'x25 idle' to set the tear-down timer for idle connections, but I am not sure if it applies to PAD connections. Check out if this command helps you. Anyway, the best source of information is the configuration guide and command reference which you can find at :
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fwan_c/wcfx25.htm
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fwan_r/x25cmds/index.htm
