Warning message
CM 3.1 Multifix patches, NM-HDA
Answered Question
May 27th, 2003
Are Multifix patches cumulative patches ?
If I install Multifix Patch "D" , does this mean I dont need to install "A" "B" and "C". "D" just takes care of everything ?
NM-HDA on a 2620XM with 12.2(11)T IOS, CM 3.1 does not recognize NM-HDA
using MGCP. Which CM works with NM-HDA using MGCP ?
thanks,
Correct Answer by mowour about 14 years 2 months ago
1. The multifix patches are indeed cumulative.
The ReadMe for CallManager 3.1(4b) Support Patch D states as follows: This Support Patch is a cumulative update containing all the fixes and changes from prior 3.1(4b) support patches.
2. Support for the NM-HDA is available as of CallManager 3.2(2c)spA.
Hope this helps.
Mike.
Overall Rating: 5 (1 ratings)
Correct Answer
mowour Wed, 05/28/2003 - 20:08
Hope this helps.
Mike.
