Warning message
Upgraded from CM 3.1.2c to 3.2.3. Errors on install
May 28th, 2003
When I went through the steps listed in the upgrade process, everything went fine until the upgrade process of the actual call manager software. I kept getting this error message in the background that said "IIS40Helper".
Can anyone shed some light on this matter. The Callmanager seems to be working ok. I kept the mirrored HD out in case I need to go back to the old 3.1.2
marinaibm Wed, 05/28/2003 - 19:19
  • Silver, 250 points or more
Hi Charles,
I believe it's just a cosmetic bug, as its workaround is to " click the "ok" button" :-)
You would probably like to contact TAC to verify the status
CSCdt27399 Bug Details
Headline Message box titled IIS Helper... appears with an OK button
Severity 3
Status Verified
First Found-in Version 3.1(0.1.1)
WORKAROUND:
Click to "OK" button
