3002 hardware client questions
Answered Question
Can you use a dynamic external ip address with the 3002 hardware client, or does it have to be static? I'm assuming you can use one in client mode, but what about in network extension mode? Also, I just wanted to verify that an external switch or hub can be used with the single internal port version in order to support multiple hosts. The 3002 Q&A page was a bit unclear on this.
Thanks for the help,
Adam
Correct Answer by travis-dennis_2 about 14 years 2 months ago
Yes and Yes.
You can use DHCP on the outside interface on a 3002 using Network Extantion mode.
You can use an external switch or hub with the single internal port version.
No links to send your way but I have personally done it(and am doing it now)
Overall Rating: 5 (1 ratings)
Correct Answer
travis-dennis_2 Thu, 05/29/2003 - 08:47
  • Gold, 750 points or more
Yes and Yes.
