Interference
May 29th, 2003
I have a municipality client that wants to put an omni-directional antenna on a water tower for their 11b network. They have also been approached by a cellular carrier for permission to locate their antennas atop the water tower. What sort of interference or problems can I expect with the co-location of the cellular antennas and an 11b antenna on a single structure?
derwin Thu, 05/29/2003 - 17:14
  • Cisco Employee,
You should be fine,
Cellular carriers are normally 900Mhz 1800Mhz or 1900Mhz depending on the location in the world
WLAN is 2400Mhz
The cell phone bands are not a harmonic of WLAN or are they in the same band so the interference should not be an issue.
Just watch that the antenna is not placed in the line of sight or frensnel zone, and would provide some physical separation on the roof, ie. dont put them right on top of each other.
The cellular guys have more to loose with interference so they wouldnt have approached you if it was going to be a big problem
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
